FCC 认证中的VOC和DOC
Jellyyl 发表于 2010-10-30 09:11:42 | 显示全部楼层 |阅读模式 打印 上一主题 下一主题
----------Jelly yang   转载整理
     遇到很多客户问我, 为什么我们要建议他们的无线产品的接收部分去做 ID, 或者申请台湾, HK的DOC, 这样会给他们增加成本, 问, 为什么大陆很多实验室都在出DOC, 为什么你们要这么做? 现在给大家做一个忠告和澄清: 根据我在FCC 网站查到的信息, 有如下一个提问:
     How can it be determined that a specific test firm facility may be used for testing in support of a Declaration of Conformity (DoC) test report?
      FCC 是这样解释的:
Per Section 2.948 (d) and (e) of the FCC rules, in order for a DoC test report to be acceptable for a product to be marketed in the U.S., the testing must be performed at an ISO/IEC 17025 accredited test firm that is recognized by the FCC.
A list of recognized test firms appears on the FCC website at:https://fjallfoss.fcc.gov/oetcf/eas/reports/TestFirmSearch.cfm
Select the "accredited" option to search for FCC recognized accredited test firms. For test firms that choose the "non-contract" option for their test site, the information regarding the FCC recognition is not publicly available.
For test firms outside the U.S., recognition is only possible for those test firms located in countries with which the U.S. has an operational Mutual Recognition Agreement (MRA).
For a test firm that has multiple facilities, the specific test facility used for the DoC testing must be a location assessed as part of the ISO/IEC 17025 accreditation, and the facility must be recognized by the FCC. Test facilities located in countries where the U.S. does not have an operational Telcom MRA are not recognized by the FCC. Therefore a test firm with facilities located in a country without an operational Telcom MRA may not use the facilities in the non-MRA country for DoC testing to FCC requirements.
      这里面的关键词是: 2.948, Test Firms Qualified for DOC Test Reports, MRA, List of Test Firms
      所以很明显, 你必须在具备以上所有条件的实验室测试并申请DOC, 但大陆是没有MRA的, 也就是说, 虽然大陆有好几个实验室是在FCC list 下的, 但如果出具DOC, 仍是不合法的, 同时, 在2007年12月15日左右, FCC给了一个order 给各TCB, 大致内容是:
     FCC had given the order that TCBs have to verify the DoC issue when the product combines DoC issue. I believe this is for preventing Chinese applicants using illegal DoC test report issued by any lab located in China
     所以我们衷心的建议要做DOC的生产商或申请商, 请严把自己的认证关, 不要再乱做DOC了, 为了你们的长久利益, 为了中国企业的声誉, 让我们一起, 依法做好产品认证吧!
abc3422124 发表于 2012-8-17 14:26:59 | 显示全部楼层
FCC认证分为VOC和DOC ,无线产品做FCC必须申请ID,大陆实验室是肯定做不了DOC的,如果有做电脑周边产品的FCC认证的厂家,DOC是肯定是到香港或者台湾检测的,价格不可能很低,那种很低的,那肯定是骗人的啦。我们是FCC列名实验室,有申请FCC认证的朋友可以联系我
courage 发表于 2012-8-18 09:12:52 | 显示全部楼层
2#楼是深圳哪个实验室?
北测检测Tand 发表于 2014-5-5 11:39:31 | 显示全部楼层
fcc一般有三种认证方式:voc doc id ,voc国内授权实验室能做的,doc是美资实验室,id的话授权实验室可以用voc转。所以基本要做的话就做FCC ID就OK了
stone0371 发表于 2014-5-5 13:09:45 | 显示全部楼层
楼主能不能告诉我关于英文的部分,在FCC网站具体那个地方,我也研究下,谢谢。
