ETSI 301 489上有规定的,RS肯定有豁免频段的:
The exclusion band for immunity testing shall be calculated as follows:
• lower limit of exclusion band = lowest allocated band edge frequency -5 %;
• upper limit of exclusion band = highest allocated band edge frequency +5 %.
Using the 2,450 MHz band as an example:
• lower limit of exclusion band = 2 400 - 120 = 2 280 MHz;
• upper limit of exclusion band = 2 483,5 + 124,175 = 2 607,675 MHz;
• thus the exclusion band for 2,45 GHz equipment falling within the scope of the present document extends from
2 280 MHz to 2 607,675 MHz.
