寬帶扼流線圈 YPWB
yp_beads 发表于 2013-5-14 10:59:02 | 显示全部楼层 |阅读模式 打印 上一主题 下一主题
Features (六孔磁珠特长)
The wide band choke cores mainly used in the PC boards to filters the EMI from the outsides. (寬頻的扼流線圈主要應用在主機板上防止外來的電磁波干擾)
● Ferrite core construction of low cost (低成本之鐵氧體結構)
Applications (六孔磁珠用途)
● Personal Computer and electronic products(電腦及電子產品)
Product Identification (產品識別)
YPWB  _____ - _____Ts (Ex. YP WBR6H - 2.5Ts)
  1   2     3
       1. Wide Band Chokes (寬帶抗流線圈) (YPWB)
       2. Hole (孔) → R6H (六孔磁珠)
       3. No. of Turns (圈數)
Configurations & Dimensions (六孔磁珠結構圖及規格尺寸)
file:///C:/DOCUME~1/dell/APPLIC~1/360se6/USERDA~1/Temp/WBR6H1~1.GIFfile:///C:/DOCUME~1/dell/APPLIC~1/360se6/USERDA~1/Temp/WBR6H1~1.GIF
        Unit In mm
Type (型式)Impedance(Z)
(Ω)(min)
阻抗值
ÆA
±0.5
B
±0.5
C
±3.0
ÆD
±0.05
10MHz50MHz10
YP WBR6H - 1.5Ts1703203756.010.025.00.5 / 0.6
YP WBR6H - 2.5Ts3206805806.010.025.00.5 / 0.6
YP WBR6H - 3.0Ts4008005506.010.025.00.5 / 0.6
YP WBR6H - 1.5+1.5Ts1703203756.010.025.00.5 / 0.6
※Design as Customer’s Requested Specifications. (可依客戶特殊需求設計)
●Impedance vs. Frequency Curve
