1.Effective Radiated Power (E.I.R.P):PK:20dBm / AV 20dBm
2.Transmitter Power Density:10dBm / 1MHz (DSSS)
20dBm / 100 kHz (FHSS)
3.Frequency Range of Equipment Using modulation:FL>2400 MHz , FH<2483.5 MHz
4.Spurious emission (TX)(Radiated/Conducted):
Frequency Range Limit when operating Limit when in standby
30MHz to 1GHz -36dBm -57dBm
Above 1GHz to 12.75GHz -30dBm -47dBm
1.8 to 1.9GHz/5.15 to 5.3GHz -47dBm -47dBm
5.Spurious Emissions(Radiated/Conducted):
30MHz to 1000MHz : -57dBm
Above 1000 to 12.75GHz : -47dBm
