3.9 toy
product designed for, or clearly intended for use in play by children under 14 years old.
Toys may incorporate motors, heating elements, electronic circuits and their combination.
The supply voltage of a toy shall not exceed 24 V a.c. (r.m.s) or ripple-free d.c. and may be
provided by a battery or by means of an adapter or a safety transformer connected to the
mains supply
NOTE Transformers, converters and chargers for toys are considered not to be part of the toy (see IEC 61558-2-7).
3.10
battery
3.10
battery toy:电池类玩具
toy which contains or uses one or more batteries as the only source of electrical energy
3.11
transformer toy:变压器类玩具
toy which is connected to the supply mains through a transformer for toys and using the
supply mains as the only source of electrical energy
3.12
dual supply toy:双电源玩具
toy which can be operated simultaneously or alternatively as a battery toy and a transformer toy
3.14 safety isolating transformer:安全隔离变压器
transformer, the input winding of which is electrically separated from the output winding by an
insulation at least equivalent to double insulation or reinforced insulation, and which is
designed to supply an appliance or circuit at safety extra-low voltage。
安全隔离变压器的主要特点是输入绕组和输出绕组之间的绝缘等级相当于双重绝缘或者是加强绝缘,并且强调是给器具供电或者是给工作在安全特低电压下的电路供电的。
这里面有三个定义:双重绝缘、加强绝缘和安全特地电压。这几个定义安规工程师很熟悉的,在IEC 60335-1或者是GB4706.1中有详细的解释。有兴趣的朋友可以查阅下相关标准。
3.15 safety transformer for toys:玩具用安全变压器
safety isolating transformer specially designed to supply toys operating at safety extra-low
voltage not exceeding 24 V
NOTE Either a.c. or d.c. or both may be delivered from the transformer unit.
该条款比较简单,就是说出了对玩具用的变压器的要求,不多做解释。
3.16 constructional kit:装配用配套元件
collection of electric, electronic or mechanical parts intended to be assembled as various toys
3.17 experimental kit:试验用配套元件
collection of electric or electronic components intended to be assembled in various
combinations
NOTE The main aim of an experimental set is to facilitate the acquiring of knowledge by experiment and research.
It is not intended to create a toy or equipment for practical use.
3.18 functional toy:功能性玩具
toy with a rated voltage not exceeding 24 V and which is a model of an appliance or
installation used by adults
NOTE A product with a rated voltage exceeding 24 V, intended to be used by children under the direct supervision of an adult and which is a model of an appliance or installation and used in the same way, is known as a functional product.
3.19 portable luminaire for children
luminaire that in normal use can be moved from one place to another while connected to the
supply and which is designed to provide a level of safety in excess of that provided by a
portable general purpose luminaire conforming with IEC 60598-2-4
NOTE A portable luminaire for children is intended for use by children who may not be under the supervision of more competent persons at the time of use.[IEC 60598-2-10: 10.3.1]
3.20 video toy
toy consisting of a screen and activating means by which the child can play and interact with
the picture shown on the screen
NOTE All parts necessary for the operation of the video toy, such as control box, joy stick, keyboard, monitor and connections, are considered to be part of the toy.
3.22 electronic component
part in which conduction is achieved principally by electrons moving through a vacuum, gas or
semiconductor
NOTE Electronic components do not include resistors, capacitors and inductors.
电子元件:主要通过电子在真空、导体或者半导体中的运动,实现传导的部件。
注:电子元件不包括电阻、电容和电感。
应用的角度来说,我们只要把电阻、电容和电感划分出去,其他的都可以归为电子元件。
至于从微观的角度该怎么理解,我现在也没有参悟透,请高手出来指点指点吧。
