4.2.3.2 Combination of clicks in a time frame less than 600 ms
In programme controlled appliances a combination of clicks in a time frame less than 600 ms is allowed once per selected programme cycle.
For other appliances such a combination of clicks is allowed once during the minimum observation time. This is also valid for thermostatically controlled three-phase switches, causing three disturbances sequentially in each of the three phases and the neutral. The
combination of clicks is considered as one click.
4.2.3.3 Instantaneous switching
Appliances which fulfil the following conditions:
– the click rate is not more than 5,
– none of the caused clicks has a duration longer than 20 ms,
– 90 % of the caused clicks have a duration less than 10 ms,
shall be deemed to comply with the limits, independent of the amplitude of the clicks (see tables A.1 and A.2). If one of these conditions is not satisfied then the limits in accordance with 4.2.2 apply.
4.2.3.4 Separation of clicks less than 200 ms
For appliances which have a click rate less than 5, any two disturbances each having a maximum duration of 200 ms, shall be evaluated as two clicks even when the separation between the disturbances is less than 200 ms.
In this case, for instance observed with refrigerators, the example shown in Figure 4b, would be evaluated as two clicks and not as continuous disturbance.
5 Methods of measurement of terminal disturbance voltages (148,5 kHz to 30 MHz)
This clause lays down the general requirements for the measurement of disturbance voltage produced at the terminals of apparatus.
The operating conditions are given in Clause 7 of this standard.
5.1 Measuring devices:测量设备
The measuring devices given below are to be used:
5.1.1 Measuring receivers:测量接收机
Receivers with quasi-peak detectors shall be in accordance with Clause 4 of CISPR 16-1-1;receivers with average detectors shall be in accordance with Clause 6 of CISPR 16-1-1.
NOTE Both detectors may be incorporated in a single receiver and measurements carried out either using the
quasi-peak detector or the average detector.
