5 Methods of measurement of terminal disturbance voltages (148,5 kHz to 30 MHz)
This clause lays down the general requirements for the measurement of disturbance voltage produced at the terminals of apparatus.
The operating conditions are given in Clause 7 of this standard.
5.1.1 Measuring receivers:测量接收机
Receivers with quasi-peak detectors shall be in accordance with Clause 4 of CISPR 16-1-1;
receivers with average detectors shall be in accordance with Clause 6 of CISPR 16-1-1.
NOTE Both detectors may be incorporated in a single receiver and measurements carried out either using the quasi-peak detector or the average detector.
5.1.2 Artificial mains network:人工电源网络
The artificial mains V-network is required to provide a defined impedance at high frequencies between the terminals of the equipment under test and reference ground, and also to isolate the test circuit from unwanted radio-frequency signals on the supply mains.
The artificial mains V-network 50 Ω/50 μH (or 50 Ω/50 μH + 5 Ω) as defined in Clause 4 of CISPR 16-1-2 shall be used.
To ensure that, at the frequency of measurement, the impedance of the mains does not materially affect the impedance of the artificial mains V-network, a suitable radio-frequency impedance shall be inserted between the artificial mains V-network and the supply mains.
This impedance will also reduce the effect of unwanted signals which occur on the supply mains (see also 5.3).
The connection between the artificial mains V-network and the measuring receiver shall be made by means of a coaxial cable with a characteristic impedance of 50 Ω.
5.1.3 Voltage probe:电压探头
The voltage probe shall be used when measuring on terminals other than mains terminals (see 5.2.3.2) e.g. load and control terminals (5.2.4.4). The voltage probe shall also be used on mains terminals when the artificial mains V-network cannot be used without unduly
influencing the equipment under test or the test equipment, e.g. while measuring motors and heating devices operating at more than 25 A per phase.
The voltage probe contains a resistor having a resistance value of at least 1 500 Ω in series with a capacitor with a reactive value negligible to the resistance (in the range 150 kHz to 30 MHz) (see 5.2 of CISPR 16-1-2).
The measuring results shall be corrected according to the voltage division between the probe and the measuring set. For this correction only the resistive parts of the impedances shall be taken into account.
If the function of the equipment under test is affected by the impedance of the probe being too low, its impedance (at 50/60 Hz and at radio frequencies) shall be increased as needed (for example 15 kΩ in series with 500 pF).
5.1.4 Artificial hand:模拟手
In order to simulate the influence of the user's hand, application of the artificial hand is required for hand held equipment during the disturbance voltage measurement.
The artificial hand consists of metal foil which is connected to one terminal (terminal M) of an RC element consisting of a capacitor of 220 pF ± 20 % in series with a resistor of 510 Ω ± 10 % (see Figure 8a); the other terminal of the RC element shall be connected to the reference ground of the measuring system (see CISPR 16-1-2). The RC element of the artificial hand may be incorporated in the housing of the artificial mains network.
