An initial survey or scanning of the complete range shall be made. In the case of quasi-peak detector measurement, the registered values shall be given at least at the following frequencies and at all frequencies at which there is a maximum:
160 kHz, 240 kHz, 550 kHz, 1 MHz, 1,4 MHz, 2 MHz, 3,5 MHz, 6 MHz, 10 MHz, 22 MHz, 30 MHz.
These frequencies are to be subject to a tolerance of ±10 %.
应在整个频段内进行初步观察或扫描,对于准峰值检波器测量,应至少在下列频率点和有最大骚扰的所有频率点上给出记录值:
上述频率的容差为±10 %。 |
