7.3.4.5 Thermal and non-thermal storage water heaters shall be operated in usual position of use, filled with typical quantity of water; no water to be drawn off during test. The click rate N shall be determined with the highest setting of any control device fitted.
7.3.4.6 Steam generators for indirect heating of appliances e.g. used in hotels and open water baths, shall be operated using the typical quantity of water.
7.3.4.7 Warming plates, boiling tables, heating drawers, heating cabinets shall be operated with no load in the heating compartment or on the heating surface.
7.3.4.8 Cooking ovens, grills, waffle irons, waffle grills shall be operated with no load in the heating compartment or on the heating surface, the oven door being closed.
电热烤箱、烤架、华夫烙饼锅、华夫烤架应在加热隔间或加热表面空载,且箱门关闭的条件下运行。
NOTE The microwave function, if any, is covered by CISPR 11.
All other toasters are to be tested according to 7.3.4.9.1 or 7.3.4.9.2 using as normal load slices of white bread about 24 h old (dimensions approximately 10 cm × 9 cm × 1 cm) to produce golden-brown toast.
所有其他考面包机应按 7.3.4.9.1 和 7.3.4.9.2 进行测试,使用放过24h的白面包片(尺寸约10 cm × 9 cm × 1 cm )作为正常负载,将面包烤成金黄色。
7.3.4.9.1 Simple toasters are toasters which: 简单的烤面包机
– incorporate a manually operated switch for switching on the heating element at the start of the toasting cycle and which will switch off the heating element automatically at the end of a predetermined period, and
Using the normal load the manual control shall be set to give the required result. With the appliance in a warm condition the average "on" time (t1 seconds) of the heating element shall be determined from three toasting operations. A rest period of 30 s shall be allowed after each "on" time.
